2 members (klhansen, 1 invisible), 88 guests, and 5 robots.
Topics128,126
Posts1,056,356
Members48,441
I know this has been discussed many times and I have read some of the posts, but I'm still uncertain. I have a 48' big bolt that had a positive battery cable attached to the frame and a negative cable to the starter with solenoid. The coil is connected with negative. I found a foot starter at a salvage yard from a truck just like mine in every way except the starter was connected with a positive battery cable. Was my truck wired wrong or the one in the salvage yard?
"48 big bolt" doesn't tell us much about what you have. If yours is a GMC it came with positive ground.
sorry cletis,
I have a chevy loadmaster, 2 ton, 235 engine, 4 speed trans and 2 speed timken rear.
should be a neg ground......
Redryder pix
My Hotrod
Agree with joker...and, joker, love that side molding trim on the '52 hotrod!
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
maybe the previous owner wanted it to be like a gmc grin
