| | | Forums66 Topics128,090 Posts1,056,018 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 148 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 148 | still having trouble removing brake drum. removed spindle nut & washer, backed of brake pad adjustment totally and still canot remove drum. Was told problem could possibly be rust ring. I used a puller once but did not come of them. I have bought inner and outer bearings so not worried if they get damaged by removing drum, is there anything else i need to worry about before i put puller back on and give it all i can? any insight would be greatly appreciated. Thanks in advance,red49. | | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | Soak it down in PB Blaster (or any good penetrant) and let it set for a while. Then get your BFH and whoop the tar outta' that drum (between studs). Put your puller on it if it don't come loose, crank some tension on it and beat the snot out of it some more. Good luck!! | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy red49, there is a chance that the inner bearing could be rusted/siezed to the spindle, a good puller will pull the hub off leaving the inner bearing and seal on the spindle, good luck. | | | | | Joined: Sep 2011 Posts: 148 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 148 | tcox,3B, thanks for the response. I just wanted someone to tell me that my BFH would finally work. Soaked it down an will get er tomorrow morning. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think you are trying to remove the hub, correct? There is no place for a big hammer in removing the hub. If you have the nut and waasher off, the inner bering race should slide off. normally a little push inward on the drum will cause the bearing to pop out. | | | | | Joined: Sep 2011 Posts: 148 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 148 | Hey truckernix, what i am seeing is after I removed the spindle nut and washer the metal housing that holds the bearing balls in place was apart, what I have now is the b balls are still there with a sleeve on the spindle keeping them from coming out. I have tried to gently smack that sleve to see if it will move in or move at all and it is really stuck. Ican grab on to the brake drum and it moves in and out about 1/4" and that is all. I really do not understand what is going on. | | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | Bolt a piece of heavy tow chain to one of the lug studs, back off a few feet, and give it a "whiplash" motion. The hub and drum should come off after a few good yanks. Jerry
| | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Okay, sounds like two different operations are being discussed here... One type of drum slips over the lugs and comes off leaving the hub and bearings on the spindle. This one sometimes needs heat or the BFH between the lugs to loosen it around the hub boss. The other type is riveted to the front or back of the hub face and must be removed with the hub and bearings from the spindle. The only thing keeping the hub in place after the nut and washers are removed is the inner bearing race of the outer bearing. Until it is removed, the hub isn't moving. If this race is rusted to the spindle, you have some work to do. PB Blaster for a night, then you need to get it to start moving. Hammer and chisel to turn the race on the spindle to break the rust. Last resort, drill through the race on one side, stepping up the size until it is possible to cut the race on one side and expand it with a chisel or screwdriver blade. The race is hardened, so you're going to need good drills for this job.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I would go with Jerry's method although I would use two studs to keep the bar straight. | | |
