| | | Forums66 Topics128,203 Posts1,057,286 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 141 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 141 | Can I please get some help instructing me in testing a starter. It's out of the truck and I would like to see if it works. I just need to know how to run the wires. Thanks. [IMG] http://img.photobucket.com/albums/v617/daniel1060/1946%20GMC%20Truck/TruckParts.jpg[/IMG]
Trombones Totem Poles And Old Trucks!
| | | | | Joined: Feb 2004 Posts: 29,879 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,879 | The item in your pictue is not a stomp starter- - - -it's got a solenoid on it. Connect the big yellow cable to the battery + terminal, and ground the other battery post to the starter housing. Jumper cables will work well for that. Then touch the small black wire to the terminal where the yellow cable attaches. The starter pinion gear will snap out into the nose cone and the armature will spin with enough torque to try to rotate the starter housing, so it's best to have it clamped in a vise before making any connections. Jerry
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | This is a foot starter (Stomp) ...pic... | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the "plunger" is activated by the solenoid it's connected to - someone replace the original foot operated starter with a key operated one and saved you the un-needed parts
Bill | | | | | Joined: Nov 2011 Posts: 141 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 141 | Thanks!! I understand now!!!!! LOL!!!
| | | | | Joined: Nov 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 190 | not sure how to post a picture on here but if you look at ebay item 270924978519 that is a "stomp" starter. | | | | | Joined: Nov 2011 Posts: 141 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 141 | Thanks for that! Will that starter fit in my 46 GMC w/ 248? The auction didn't say it would but I would think its the same
| | | | | Joined: Nov 2009 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 67 | Maybe I should restor my stomp starter if I'll get that much for it hahaha And to think it was just going to the scrap yard. Guess I should test it and see if it's still good after sitting for 15yrs. | | | | | Joined: Nov 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 190 | Yes, it will fit your GMC. There were differences in the GMC starter and the Chevy starter but most folks never know about them . The GMC starters actually had a slightly different shift lever called a "split lever". This different shift lever caused the cast iron drive end housing to be different. Both starter had the same armature, coils, drive and switch but different housings. However, they are both completely interchangeable with one another. The housing is only different where the shift lever is involved. Again, they are interchangeable even though Delco would have issued different part numbers for both starters. Even though I know all this, I cant for the life of me tell you why GMC, Chevy, Delco, felt the need to make two different shift levers and housings for the trucks back then when internal parts were all the same and mounting was the same. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Could it have had something to do with positive and negative ground and being able to immediately tell the difference? | | | | | Joined: Nov 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 190 | Could it have had something to do with positive and negative ground and being able to immediately tell the difference? No, pos. and neg. ground made no difference to the starter. It would work either way. | | | | | Joined: Feb 2004 Posts: 29,879 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,879 | That thing looks like it's been underwater for a few years! The first thing I'd suggest is to get about 5 pounds of rust off everything! Jerry
