4 members (Mr Crosswrench, RLB, klhansen, 1 invisible), 108 guests, and 3 robots.
Topics128,133
Posts1,056,395
Members48,441
I found a set of aluminum 22.5 wheels for my 57 LCF. Would I need longer wheel studs for the aluminum wheels? I am concerened about the thickness of the wheels compared to the steel. My front studs just slightly stick out past the end of the lug nuts with steels wheels. I would hate to spend the money on the wheels only to find out that it is going to involve a lot more work.
Shane
1959 Apache 3100 Fleetside
1959 Apache 3200 NAPCO
1957 Chevy 5700 Low Cab Forward
1959 GMC F370 LCF
Another 1959 Apache 3100 Fleetside
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
It's very likely,
You won't know for sure untill you measure or test fit one.
Stud Centered Budd wheels I assume?
I'm guessing you'll need longer studs all the way around as well as inner nuts for the rear, they shouldn't be hard to get all. Try Randall at Central Truck and Trailer in Hagerstown, MD 301-797-1995, tell him Grigg sent you.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Thanks Grigg, yes they are stud centered budd wheels. Still not sure about them. I like the look of the 6 hand hole wheel and the aluminum have 10 small hand holes.
Shane
1959 GMC F370 LCF
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
