1 members (RLB),
215
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2001 Posts: 199 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 199 | I found a set of aluminum 22.5 wheels for my 57 LCF. Would I need longer wheel studs for the aluminum wheels? I am concerened about the thickness of the wheels compared to the steel. My front studs just slightly stick out past the end of the lug nuts with steels wheels. I would hate to spend the money on the wheels only to find out that it is going to involve a lot more work. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | It's very likely, You won't know for sure untill you measure or test fit one.
Stud Centered Budd wheels I assume?
I'm guessing you'll need longer studs all the way around as well as inner nuts for the rear, they shouldn't be hard to get all. Try Randall at Central Truck and Trailer in Hagerstown, MD 301-797-1995, tell him Grigg sent you.
Grigg | | | | | Joined: Apr 2001 Posts: 199 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 199 | Thanks Grigg, yes they are stud centered budd wheels. Still not sure about them. I like the look of the 6 hand hole wheel and the aluminum have 10 small hand holes. | | |
