1 members (papas52),
111
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,105 Posts1,056,542 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 146 | I came across new parking lamp assemblies that have a single wire (original) or double contact for turn signals. My truck's lights only had a single wire, but also has a turn signal switch. How would I wire the new lamps with 2 wires? Also, when checking the voltage at the wires' junction plate, the park lamp wires aren't powered when the headlight switch is "on". Only when the switch is half way or "park" position. Aren't these lights supposed to be on with the headlights? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | No, they are just as you typed, "park"ing lamps. They are wired just like the tail lights, that is, one wire is for the parking light and the other for the brighter, turn signal. The original wiring did not have a provision for turn signals they were an add-on so a separate wire has to be added to the loom for each side. Denny G
Denny G Sandwich, IL
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Early SignalStat turn signal switches (and other brands) flashed the single wire park lamps and tail lights, just not very brightly. An additional wire was not required. I believe that the switches had only four wires.
Later SignalStat switches with more wires (8?) were for brighter dual filament park and tail lights.
Not sure if your single filament turn signal switch will work with double filament bulbs.
Yep - park lights did not come on with the headlights. Don't know when that changed.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The signal switch with 4 wires requires separate light assemblies for the signals. A 7 wire uses the brake lights and the brighter side of a 2 filament bulb in front. An 8 wire uses the park light single filament bulbs and the brake light bulbs. | | | | | Joined: Oct 2010 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 171 | I used the dual filament bulbs in my parking light.....Have most of ya'll wired the parking lamps so that they are only on when the switch is half way out or to the same terminal as the headlights are on. I just finished the wiring and thought I wired something wrong because the parking lights when off when the head lights came on.
....David
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | As stated above, The park lights are for parking. They do not come on when the headlights are on if wired properly. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Cletis, thanks for the correction - I shoulda counted the number of wires required for turn signals for single filament park lamps and brake lights. Yes, needs more than four wires. Here is one of the patents for the switch that uses single filament park lights. "... the 'stop' and parking lamps of a vehicle can be used as turn indicating signals. Thus, the need for extra signal lamps for turn indication, and their associated wiring is eliminated." Can oldchevytrucks' signal switch for single filament park lights work with double filament park lights?
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Can oldchevytrucks' signal switch for single filament park lights work with double filament park lights? I expect they could. | | |
