8 members (mk72, Gdads51, ShopRag, TUTS 59, Hush, Otto Skorzeny, Hugh63c10, Hanks custodian),
149
Mod | | | Forums66 Topics128,043 Posts1,055,524 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 66 | Well after a couple of years on a timeout, I'm finally back to working on my 53 3100. I already got the frame ready and grafted a Monte Carlo front end on it. Previously, the frame had been stripped by an aquantance that was helping out. Unfortunately he lost a lot of items including the rear cab shackles. I found a place where I can buy them though I couldn't find the mounting hardware for them. I also already purchased the front mounting kit. So my question, does anyone have any guidance on purchasing these items or what else I may need as well as installation advice? Also, I saw some talk about not using shackles and using something a little more modern but wasn't sure if this was something I should consider. I'm pretty much a newb when it comes to this truck so I'm learning as I go and any advice would be greatly appreciated. Tks | | | | | Joined: Oct 2009 Posts: 201 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 201 | If you search on cab mounts or frame stiffening I think you'll find a lively discussion that was had a while back regarding frame flex. The older frames flex quite a bit especially in torsion and so the spring mounts are required to keep the bolts from ripping though the sheet metal and or wrinkling the cab. If you stiffen the frame while you've got it apart (and aren't worried about keeping it all original) then with adequate stiffening you could skip the springs and go to a solid mount.
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
| | | | | Joined: Nov 2005 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 66 | I did find some older threads. I'll look around some more...tks | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Here are some pics from my 50 ...pic... You will need to get the fasteners and make a threaded plate for the inside of the cab. If you do get replacement shackles make sure they are the right ones. I believe the larger trucks shackles look the same but the mounting bolt locations are different and they are wider. You will need to get the clearance called out for in the manual correct, otherwise you may have problems lining up the front sheet metal. The Manual call out for shims, if needed. Good Luck | | | | | Joined: Nov 2005 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 66 | Thanks for the pics...just what I needed. I did just get lucky and find my shackles so I gotta look into the thread plates and bolts now. Thanks again... | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | mario23 where'd you find the shackles? i've missed placed mine and may need to get new ones thanks rolf
1963 c10 | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | thanks tim they don't look like mine but then i can't find them right now. i remember bagging the old cab mounts and putting them with all the other stuff i took off. now i can't find them. i'll keep looking but when it comes time to put the cab on i'll need some
thanks again
rolf
1963 c10 | | |
