4 members (Peggy M, Oswald, Wayne67vert, 1 invisible), 90 guests, and 2 robots.
Topics128,060
Posts1,055,839
Members48,427
#829816 02/26/2012 3:20 AM
Here's a link to one of the 250's we just built. 2 more are in the works as well as TWO 292's.
(I posted this on Inliners, but just in case someone on SB wants to view it.)
This one has 'chamber' work, i.e., bigger valves - 1.94 / 1.50, Chevy 307 Flat Top Pistons, the Intake Bosses removed (but not Lump Ported)running an Edelbrock 4 bbl 500 cfm manuel choke on an Offy Intake, Custom Grind Cam and Hedman dual long headers.
Hawkins Custom Machine Shop did the work.
Enjoy!
If at first you don't succeed . . .
er . . . then skydiving may NOT be for you!
1946 Chevy 1.5-Ton Flatbed Completed
1946 Chevy 1.5-Ton Just getting started
Timmer #829978 02/26/2012 7:11 PM
Sweeeet.
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
**hi i just puled another 250 ci from a 66*well cared for,converted c-10 to a flat bed, was in a wreck,ouch,but sadestthing is i didnt get the 4 on the floor trannie in time for my 66 panel 3 on tree.,stuffs goin to china in a black faster than ya can slurp a ramen noodle,sad an sadder..but**whered i find specs like these that ya use to in ball park,id love to drop one in a car shell i have in my yard,lil 60,s boxy tank.all will work as fitting ect did that homework fun,w/ lil hammer n scredriver like ya said will travel..sweet work and i,m in new mexico any way to fnd where ya are and talk 250,s 1 day??.and aboutthe rough geustimate on theparts cost!!tally up.i have few sweet old 60,s 70,s carbs,n manifolds i made ions ago.i love the 250 the 292 is a gas slug w/ lil more oommppf.have few dorf st 6,s//have ya checked out inlinesixes.com great site for 6 cyl enthusiasts..sweet post thanks.landspook ,frankenstein 66'............
have the fever with no cure eccept to getter done.
Capital letters, complete sentences and correct punctuation are your friends.- - - - -This is a forum, not a cell phone!
you are the man JERRY,,,
johnhull #830043 02/26/2012 11:15 PM
I was thinking the same thing Jerry. You've saved me the trouble of saying it. WTF?
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Originally Posted by landspook
,**forgive my spelling and pc skills i,molder and still use handtool and no tv!!
bein a merchant marine in 2 wars...2 and korea..?i,m new to pc stuff and dont care for it..but i wanna share and learn too..
Thank you for your service.
Proud to have you with us
DADS50 #830348 02/27/2012 9:18 PM
OK
Now that this is Built, does anyone KNOW what the 'sweet spot' should be?
2300 rpm's?
Basically, I'd like to know what it will run at ALL DAY on the Power Tour and NOT over stress the Engine.
Timmer #830668 02/28/2012 8:38 PM
Everyone assumes these engines will only work at lower rpm's but they will easily handle a good deal more than 2300. In fact 3000 is not unreasonable to run all day.
If the engine is properly built then there is no worry. There is nothing going on inside it that isn't happening in a V8 that runs up to 3600 all day.
As for a "sweet spot" that is where it feels and sounds good. All engines will vary according to build and application.
Dave
I'll go along with that. My stock 250 "wants" to run around 3000rpm, which happens to be a little over 55mph...I have to hold 'er back!
cm
1965 Chevy C10
