1 members (lumbersawyer), 84 guests, and 1 robot.
Topics128,055
Posts1,055,782
#829377 02/24/2012 4:50 PM
I have an old Edelbrock intake that i got a long time ago, but i don't know which chevy engine it fits. I really think it is the 216, but i want to make sure. Is there a place on here that has the differences and sizes of the ports etc?
thanks,
jason
1937 GMC T16 468 BBC th350, 4.10
1941 Dodge COE 5.9 cummins, 9 speed roadranger
1947 Diamond T COE, hercules and 4 spd, all original
1955 Chevy LCF 9.0L IH diesel AT545
1962 Corvair (Elsie)
1967 Jeepster Commando
1968 K10
1970 Chevy C50 box truck
If the gasket surface from intake to exhaust is flat and in line with the intake it's 216, if slanted it's 235. If the entire intake looks crooked, meaning the intake runner look sorta twisted it's 235. Hope this helps. The later 235s were set in the vehicle nose up just a bit, so they had to tweak the intake to make the carb level.
1946 1/2-Ton Chevy
if i am following you correctly, i think it is a 216 then, i don't see anything slanted. Here are some pictures it took of it. i wrote down alot of dimensions, and now i don't know where i put them. http://s1229.photobucket.com/albums/ee466/macgyver37/edelbrock%20intake/
the reason i would like to know is to ultimately sell it. i have had it half my life and haven't done anything with it since i painted it.
thanks,
jason
1968 K10
It should noted that some of the blanket statements about differences between 216s and 235s are not correct for all 235s.
235s came out in 1941 and the intake manifolds were the same through 1949.
The 216 and 235 exhaust manifolds were the same from 41-48, And the same but different exhaust manifold in 1949.
If a W1 Carter bolts to it I would bet it is for a 216, or early 235.
Port size is smaller on those than the later 235s but I don't have the measurements in front of me.
My Blog
Here is a link to the Master Parts Manual that shows the diameters of the alignment rings for the intake ports.
There is also a difference in the flange that connects to the exhaust manifold. See group 3.272 in the link. This is more than just a 216 vs. 235 difference. The Chevs of the 40's catalogs show some of the differences.
Hoyt
well, according to the master parts cat port size, it is for a 216. mine measured 1.398-1.400 with paint on it. 1 13/32 is 1.406 which is what the master says a 216 is. thanks guys,
jason
1968 K10
Very early Edelbrock 235 big-port manifolds are marked "PG" (for Powerglide).
mo Offline
i might be interested in the manifold if your going to sell it.
MO's 1951 chevy 3100 resto mod project
nono
