2 members (Dennys28, 1 invisible),
93
Mod | | | Forums66 Topics128,059 Posts1,055,818 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 68 | I have an old Edelbrock intake that i got a long time ago, but i don't know which chevy engine it fits. I really think it is the 216, but i want to make sure. Is there a place on here that has the differences and sizes of the ports etc?
thanks,
jason
1937 GMC T16 468 BBC th350, 4.10 1941 Dodge COE 5.9 cummins, 9 speed roadranger 1947 Diamond T COE, hercules and 4 spd, all original 1955 Chevy LCF 9.0L IH diesel AT545 1962 Corvair (Elsie) 1967 Jeepster Commando 1968 K10 1970 Chevy C50 box truck | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | If the gasket surface from intake to exhaust is flat and in line with the intake it's 216, if slanted it's 235. If the entire intake looks crooked, meaning the intake runner look sorta twisted it's 235. Hope this helps. The later 235s were set in the vehicle nose up just a bit, so they had to tweak the intake to make the carb level. | | | | | Joined: Mar 2005 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 68 | if i am following you correctly, i think it is a 216 then, i don't see anything slanted. Here are some pictures it took of it. i wrote down alot of dimensions, and now i don't know where i put them. http://s1229.photobucket.com/albums/ee466/macgyver37/edelbrock%20intake/the reason i would like to know is to ultimately sell it. i have had it half my life and haven't done anything with it since i painted it. thanks, jason
1937 GMC T16 468 BBC th350, 4.10 1941 Dodge COE 5.9 cummins, 9 speed roadranger 1947 Diamond T COE, hercules and 4 spd, all original 1955 Chevy LCF 9.0L IH diesel AT545 1962 Corvair (Elsie) 1967 Jeepster Commando 1968 K10 1970 Chevy C50 box truck | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | It should noted that some of the blanket statements about differences between 216s and 235s are not correct for all 235s.
235s came out in 1941 and the intake manifolds were the same through 1949. The 216 and 235 exhaust manifolds were the same from 41-48, And the same but different exhaust manifold in 1949.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If a W1 Carter bolts to it I would bet it is for a 216, or early 235. Port size is smaller on those than the later 235s but I don't have the measurements in front of me.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | Here is a link to the Master Parts Manual that shows the diameters of the alignment rings for the intake ports. There is also a difference in the flange that connects to the exhaust manifold. See group 3.272 in the link. This is more than just a 216 vs. 235 difference. The Chevs of the 40's catalogs show some of the differences. Hoyt | | | | | Joined: Mar 2005 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 68 | well, according to the master parts cat port size, it is for a 216. mine measured 1.398-1.400 with paint on it. 1 13/32 is 1.406 which is what the master says a 216 is. thanks guys, jason
1937 GMC T16 468 BBC th350, 4.10 1941 Dodge COE 5.9 cummins, 9 speed roadranger 1947 Diamond T COE, hercules and 4 spd, all original 1955 Chevy LCF 9.0L IH diesel AT545 1962 Corvair (Elsie) 1967 Jeepster Commando 1968 K10 1970 Chevy C50 box truck | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Very early Edelbrock 235 big-port manifolds are marked "PG" (for Powerglide). | | | | | Joined: Mar 2011 Posts: 229 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 229 | i might be interested in the manifold if your going to sell it.
MO's 1951 chevy 3100 resto mod project
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | i might be interested in the manifold if your going to sell it.  | | |
