3 members (RLB, Oswald, GRNHydra),
86
Mod | | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 305 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 305 | Is there a big difference in a yfcarter Or a modle b rodchester for my 52 I belive I came with both
ya I know a few rednecks.Thay all drive chevys to, Proud member of the Old Dominion Stovebolt Society AND A MARINE trucks range from 1942 1/2 ton to 1965 fire engine
| | | | | Joined: Aug 2004 Posts: 1,417 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,417 | No. The YF is a direct replacement.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | The big difference will be how much better your engine will run with the YF Carter. You'll love it!
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
| | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | Make sure you use the right Carter YF. The right carb will swap out for you rochester. Such as a 788. Make sure you get a yf for a chevy and not a jeep or ford or some other car. You will be happy with the results.
