4 members (5 Window 9434, ronsway, NJC, dt235sd), 152 guests, and 1 robot.
Topics128,108
Posts1,056,238
Members48,437
#828924 02/23/2012 4:50 AM
I got my 66 SB started that was sitting about 12 years, then got water in the oil. i pulled off the valve cover, to start to pull the head. i noticed that the water came through what looks like a small freeze plug,that had a small rotted hole. my question is can i replace just those plugs and what are they called so i can buy some. because the head gasket looks great, no leaks.any suggestions
thanks in advance
1952 Chevy Suburban
1964 Chevy Suburban
1965 Chevy Suburban 4X4
1941 Chevy Truck
1948 Sedan Delivery
2000 K2500 Suburban
2008 K1500 Suburban
Run with the dogs or [censored] with the puppies
Riding in the Passing Lane
There are 2 small freeze plugs on the side of the head in back of the manifolds. If they leak it should not get down in the oil. You can buy them at any parts store by size. They are called freeze plugs but the real nome is core plugs.
1972 Chevy c10 Cheyenne Super
Not site of we are taking. About the same plugs. These are very small one on the head itself. Not the bigger ones on the block.
1952 Chevy Suburban
1964 Chevy Suburban
1941 Chevy Truck
1948 Sedan Delivery
2000 K2500 Suburban
2008 K1500 Suburban
I'm not sure either. It's been a long time since I worked on those 6 cyl. I know there are 2 freeze plugs on the side of the head that are only acessable with the manifolds off.
