| | | Forums66 Topics128,109 Posts1,056,258 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 98 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 98 | I got my 66 SB started that was sitting about 12 years, then got water in the oil. i pulled off the valve cover, to start to pull the head. i noticed that the water came through what looks like a small freeze plug,that had a small rotted hole. my question is can i replace just those plugs and what are they called so i can buy some. because the head gasket looks great, no leaks.any suggestions thanks in advance
1952 Chevy Suburban 1964 Chevy Suburban 1965 Chevy Suburban 4X4 1941 Chevy Truck 1948 Sedan Delivery 2000 K2500 Suburban 2008 K1500 Suburban
Run with the dogs or [censored] with the puppies
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There are 2 small freeze plugs on the side of the head in back of the manifolds. If they leak it should not get down in the oil. You can buy them at any parts store by size. They are called freeze plugs but the real nome is core plugs. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2006 Posts: 98 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 98 | Not site of we are taking. About the same plugs. These are very small one on the head itself. Not the bigger ones on the block.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Not site of we are taking. About the same plugs. These are very small one on the head itself. Not the bigger ones on the block. I'm not sure either. It's been a long time since I worked on those 6 cyl. I know there are 2 freeze plugs on the side of the head that are only acessable with the manifolds off. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
