9 members (MickeyP, papas52, Biermann, Otto Skorzeny, Donf, jmoore, Shade Baby, TS3600, BC59),
118
Mod | | | Forums66 Topics128,162 Posts1,056,949 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 6 New Guy | | New Guy Joined: Dec 2011 Posts: 6 | Would it be correct for me to assume that the suspension components such as shackles and spring pins and other frame parts from late 40's and early 50's 1/2 ton trucks are the same as my 46 half ton.NAPA does not seem to list much pre 1947 stuff but the components look the same for 47 and up.
Thanks Glenn | | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | Try looking at some of the vendors for our old trucks such as our sponsor in the left corner of your screen. I'd imagine stuff may be the same. A look at a parts book from that time period should set you straight. You may want to be more specific what you are looking for for your 1946. | | | | | Joined: Dec 2011 Posts: 6 New Guy | | New Guy Joined: Dec 2011 Posts: 6 | Thanks, Im specificaly looking at spring shackles ,spring pins and the brake components no listing for pre 1947 but alot for 1947,48,49 50 etc. Just wondering if these parts interchanged for a couple of years, makes it easier to find, noticed that some of the parts listed in vendors pages fit a number of years.
Thanks Glenn
| | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | i was told for my 37 that the front from a 51 would fit just fine plus you get the advantage of newer brake setup
1937 1/2 ton
| | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | I got all my spring pins and shackles, and all my brake stuff (wheel cylinder rebuild kits, shoes, and hardware kits, and a new master cylinder from.....www.chevsofthe40s.com | | |
