| | | Forums66 Topics128,023 Posts1,055,370 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#82827 09/11/2007 6:45 PM | Joined: Jun 2007 Posts: 95 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 95 | some of you may have read my recent posts under the title "just rebuilt - now an engine knock"....I'm sure people are tired of it re-appearing; however, the issue is still at hand. Could the harmonic balancer be causing the noise?When I re-installed the balancer after the rebuild, I just placed it over the key, whacked it a few times with a hammer as far as it would go, and that was the end of story. I'm wondering if it could have loosend up somehow, and if so, would it mimic a main bearing noise?
J.D. Jordan
#82828 09/11/2007 7:12 PM | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | If it loosened I think it would try to come completly off and make lots of noise but check and see if you can wiggle it. As far as putting it on I like to set it on a hotplate for a few minutes and then the only install tool you need is a pair of oven mitts.
Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
#82829 09/11/2007 7:42 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The balancer can make a noise similar to brg noise. The rubber could be broken between the outer ring causing a noise. Grab it & check for any looseness. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#82830 09/12/2007 12:50 AM | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | is it the old original balancer? mabey it needs replaced regardless of how you installed it. i made a brass driver to install the 250/292 ones. i had a instalation tool beak off in the crank on the tapped end on a 292. as long as they are driven on straight and only connecting with the inner portion the instillation should be ok. i have used a brass drift alternating it around but made a specific brass driver to connect all the way around and be sure to drive on straight. hey curt is the hotplate hard on the rubber ring at all. i have heard of heating them but always a little afraid to myself. hr | | |
#82831 09/12/2007 3:14 AM | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | The rubber ring is a lot more durable than the timing cover seal which would melt if it's too hot. I would guess 200 deg. F max.
#82832 09/13/2007 2:46 PM | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | | | |
#82833 09/13/2007 2:59 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If you smacked it in places other than the center lug you may have damaged the rubber dampner. Another thing to keep in mind when installing the harmonic dampner is belt alignment. While it probably won't make the noise you hear, a mis-aligned belt will wear quickly and may come off while the engine is running. You need to use a straight edge when installing the balancer to make sure the alignement is correct.
