7 members (55shaker, Jeff Ogden, RoadsScholar, Gray_Ghost, Ponchogl, fonz8261, 1 invisible),
82
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,131 Posts1,056,722 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 27 New Guy | | New Guy Joined: Feb 2012 Posts: 27 | Hi everyone im new to this site but not to 60-66 chevy Gmc trucks. My dad and I have have had dozens of them.
I need a little help on figuring my 65 Suburban 4x4 out.
I just swapped a 350 in truck and none of the gears are working. It has the 4 speed manual trans. Engine running or not it will go into all gears fine doesnt matter if clutch is in or out.
Im not sure if the trans is bad or imput shaft is broken or whats going on?
One more question. When the engines running and in gear the driveshaft to the transfer case should be spinning right? Any help would be appreciated.
VIDEO LINK-http://s283.photobucket.com/albums/kk292/94sc2/?action=view¤t=video-2012-02-16-11-00-46.mp4
| | | | | Joined: Sep 2011 Posts: 1,458 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,458 | If I understand, the trasnmission will shift into all gears & turn output shaft to transfer case. If that is the case transfer case is in neutal.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | Always have the transfer case in gear, if it's in neutral you will never go anywhere. Now, with that said, I noticed on the video that the output shaft doesn't turn ever. So, I would say you have a transmission problem.
1963 Chevy C20 Longbed Stepside 1978 Chevy K30 Custom Deluxe
| | | | | Joined: Feb 2012 Posts: 27 New Guy | | New Guy Joined: Feb 2012 Posts: 27 | Transmission will go into all gears. Transfer case was in 2W,4H,4L, and Neutral and still nothing. There is no noise or grinding or anything. Double checked all the obviouse stuff. Pressure plate is releasing clutch disc and it just wont spin the output shaft.
Its like im just dumb founded. I have no clue otherwise. | | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | I've broken a 4 speed before and after it was broke it never made a sound, just didn't make the truck go anywhere. I really think the tranny itself is the culprit. Was the 'burb ever driveable when you got it? I'm wondering if you bought it with a bad tranny and didn't know it.
| | | | | Joined: Feb 2012 Posts: 27 New Guy | | New Guy Joined: Feb 2012 Posts: 27 | Truck was all complete minus engine. trans and t case were all hooked up already. Everything looked good. The guy I got it from seemed like a real straight up guy I called him back and talked to him for a while and he seemed like there shouldnt be any problems with it. Maybe somthing i over looked or messed up with the engine install that i missed. Im not totally sure. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | sounds like the bull gear jumped the heifer gear. did you pull the gearshift out or take off the top cover? ron | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | You didn't forget to put the clutch disk in did you?
| | | | | Joined: Feb 2012 Posts: 27 New Guy | | New Guy Joined: Feb 2012 Posts: 27 | clutch is in properly and lined up. ( flywheel, clutch disc, pressure plate)
All gears shift in trans. i popped shifter out just to check of somthing wasnt lined up or somthing was off and didnt see any problems. Popped it back in and did ther half turn lock back on.
I really cant figure it out. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | With the t-case in 4-Hi or 4-Low, jack up the rear, getting both rear wheels off the ground, put the tranny in gear and spin the rear wheels, by hand. If they spin, with the tranny in gear and the t-case in gear, the problem is in the tranny case. | | | | | Joined: Feb 2010 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 38 | Does the input shaft spline match the spline in the clutch disk?
The glass is twice as big as it needs to be.
| | | | | Joined: Feb 2012 Posts: 27 New Guy | | New Guy Joined: Feb 2012 Posts: 27 | Yeah its the clutch that came with the truck that the guy had with the original 283 and 4 speed. The clutch has alot of meat on disc and I seen the pressure plate opening and closing on disc.
