1 members (1 invisible), 56 guests, and 6 robots.
Topics128,014
Posts1,055,324
Members48,419
#827088 02/17/2012 6:06 AM
My left side headlight is doing a weird thing. It's OK on high beam but on low beam it's barely at 30%. The right side light is normal. I haven't had the lights working but a couple months but this is the first time I've noticed a problem.
~Jim
Well Jim I suspect that the reason that you haven't heard from anyone today is that all the
obvious reasons for it being dim have been discussed numerous times here. Changed the
bulb? Dirty contact, connector or switch? Broken wire causing high resistance and
voltage drop at break? Taint much else that could cause it.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Yup, like Denny says, Time to get out Mr. Multimeter.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Mr. Lang #827215 02/17/2012 7:34 PM
It never ends...
~Jim
Ex Hall Monitor
Ex Hall Monitor
'Ain't that the truth.
Tiny #827239 02/17/2012 8:52 PM
It doesn't! I put a new muffler on, then I could hear how loud the trans was, so I put a floor mat and dynamat in, now I can hear my roof resonate......
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
Mr. Lang #827272 02/17/2012 11:33 PM
Well I went to the garage to test Denny's myriad of possibles and the D@mm thing is working now. I guess I'll have to evict that hamster.
~Jim
Leprechaun's! Gettin' close to St. Patty's day and they're teasing you, devilish little buggers that they are.
Denny G
Denny G
Sandwich, IL
I think you may have something there Denny. I just noticed tonight my brake lights aren't working, I spent most of two weeks with it up on the lift dealing with underside issues. I may have knocked the wires loose on the pressure switch. I'll check it out tomorrow and see if I can't break the legs on that leprechaun.
~Jim
When I think DIM lights, I always check poor ground. Been there several times!
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
40casey #828366 02/21/2012 5:14 AM
Oh man. One time, on my '50, my tail lights were stuck on sometimes, I couldn't find the reason they were always hot. I kept looking, and looking. Sometimes it would be days of normal operation, other times I'd come out in the morning and the lights would be on. The solution: The spare fuse would slip out of the holder, and lay across the contacts in the fuse block!
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
Mr. Lang #828375 02/21/2012 5:36 AM
This happened a few months back. It was the wire that returns to the circuit box that wasn't tight. I haven't had a chance to check it out as the truck is at the muffler shop having exhaust installed.
~Jim
