8 members (Gdads51, Wayne67vert, MickeyP, Cletus1950, Hotrod Lincoln, UtahYork, TexasJim50, baldeagle),
106
Mod | | | Forums66 Topics128,179 Posts1,057,068 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 3 New Guy | | New Guy Joined: Nov 2011 Posts: 3 | Bad leak from the front seal. Where do I buy the parts to fix this? Have the 4:56 diff. Thanks! By the way, just did the t-5 swap, hei ignition, carb upgrade. She runs like the wind, but that leaking diff is wrecking the buzz. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | You should be able to buy the seal at flaps. My yoke had grooves where the seal goes and I had to use a speedy sleeve. The big nut takes a whole lot of torque to remove. Folks generally use a 3/4" impact gun to do the job. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Hey Fred, if that "Speedi-Sleeve" was an SKF, you don't happen to still have the number do you????
Denny G
Denny G Sandwich, IL
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | No I don't but I believe that you can look it up on the SKF site using the diameter of the shaft. I think actually NAPA sells the seal and sleeve as a set. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yeah, I can measure it when I get it apart, and I have the SKF catalog on my computer, but because of the mild winter I'm still driving Bluebelle and I don't want to tear her apart. Was hoping you still had the numbers so I could pick one up at Motion Industries. The NAPA (Balkamp) sleeves are way cheaper than the original SKF Speedi-Sleeve but I prefer the SKF's because they have a better surface finish, have the stiffening flange on them for driving them on and come with the installation driver. Thanks anyway, DG
| | | | | Joined: Nov 2011 Posts: 3 New Guy | | New Guy Joined: Nov 2011 Posts: 3 | Thanks, guys. I'll try Napa. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Now I need the part number for my 51 1 Ton! Anyone have the part numbers for the seal and the speedi sleeve? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I have my parts now, thanks. | | |
