1 members (mick53), 202 guests, and 1 robot.
Topics128,115
Posts1,056,288
Members48,439
#827706 02/19/2012 6:55 AM
I am sure this is a first grade question but do you have to completly remove brake drum assembly to start removing king pin on my 49 chevy 1/2 ton. Also is there a bolt running through the KP that has to be removed first???
red49 #827721 02/19/2012 12:41 PM
Unless you're really lucky you'll probably need to use a fair amount of force to get the kingpin out. So having the brake backplate out of the way will be a big help to you when you need to get a big punch or drift in there.
Each kingpin is held in place by a tapered cotter pin. there's a nut on the end of this pin behind the axle eye. Undo the nut and drive the cotter pin out through the front of the axle eye with a punch.
The backing plate is shaped so that the kingpin cannot drop out. You can remove the backing plate with the wheel cylinder and hose attached and suspend it from a wire.
1951 1 Ton Completed
Shop Shark, Master Gabster, thanks so much for the response, anxious to get started, will post how it is going.
