| | | Forums66 Topics128,114 Posts1,056,282 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 148 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 148 | I am sure this is a first grade question but do you have to completly remove brake drum assembly to start removing king pin on my 49 chevy 1/2 ton. Also is there a bolt running through the KP that has to be removed first??? | | | | | Joined: Nov 2005 Posts: 238 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 238 | Unless you're really lucky you'll probably need to use a fair amount of force to get the kingpin out. So having the brake backplate out of the way will be a big help to you when you need to get a big punch or drift in there.
Each kingpin is held in place by a tapered cotter pin. there's a nut on the end of this pin behind the axle eye. Undo the nut and drive the cotter pin out through the front of the axle eye with a punch.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The backing plate is shaped so that the kingpin cannot drop out. You can remove the backing plate with the wheel cylinder and hose attached and suspend it from a wire. | | | | | Joined: Sep 2011 Posts: 148 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 148 | Shop Shark, Master Gabster, thanks so much for the response, anxious to get started, will post how it is going. | | |
