2 members (fonz8261, Oswald), 157 guests, and 3 robots.
Topics128,125
Posts1,056,337
Members48,440
#82720 09/08/2007 6:18 PM
I have a 55 Series 1 AD and am planning on going with the ubiquitous small block Chevy. Is there a rear that is a close match that could come from another vehicle? I believe that it is about 57" from drum to drum...
#82721 09/08/2007 10:46 PM
I don't think your 55-1 is different from my 51. The distance I believe you're looking for is 62" from flange to flange. If that is so, a good match would be a 70s/80s Camaro 10 bolt. There are others but this is what I used. You will need to relocate the springs but this is doable.
~Jim
#82722 09/08/2007 10:48 PM
I'm running a 3.42 88 Camaro 5 lug diff in my 54, with a 235/.72 T5, which is 62" from wheel mounting surface to wheel mounting surface...the same as the stock 54-55.1st. If you're planning on building a driver, you'll want to consider front discs. The 5 lug 89 IROC-Z (62") has a 3.08 w/posi and discs that might be just the ticket. This diff can handle up to 300HP comfortably. It was also available in 3.42 but the most common was the 3.08. Dependent on what transmission you're planning on running, these are a couple 5 lug options. Hope this helps.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#82723 09/08/2007 10:52 PM
This is a common topic here and a search should produce lots of options.
I used the rear from a '73 Chevelle wagon under mine. Had to cut off the coil and trailing arm stuff and weld on spring pads, but width wise it is perfect, and coming from a wagon, mine had 11 inch brakes which have served me well too.
Wheel mounting surface to wheel mounting surface is a better measurement, and about 62 inches is correct.
#82724 09/08/2007 11:35 PM
JTS2530,
I have read about the big block, the small block, and the crate motor, but I'll be dipped if I can find any listing for a ubiquitous block. Is this some new offshore knockoff...we should let Detroit know pronto..I smell a lawsuit. wave
Stuart
#82725 09/09/2007 1:13 AM
JTS2530,
Are you going to sell the 55.1 rear end? I would be interested.
Bill Schickling
1940 1/2 ton, 1940 3/4 ton
My web page
#82726 09/09/2007 9:39 PM
Thanks for all of the help. I'm not ready to sell anything just yet - we're still driving the 55 "as is" but are in the process of doing some research for future changes...
