| | | Forums66 Topics128,024 Posts1,055,390 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | There are three locks on the 46: Ignition, Door and Glove Box. Were there three seperate keys are were some items keyed alike? Thanks for your help. Harold
Harold Is a restoration ever finished? | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Mine has an octagon key that fits all three. Don't know if it was original or recored. Have fun and good luck Dan | | | | | Joined: Aug 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 127 | I have 1 key that fits all 3 locks, the key is not the original key but the locks and ignition are original. Rob | | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | The Owner's Manual shows two key types. One with one flat edge at the top of the key and another with all curved edges. One is used for the door lock and ignition and the other for the glove box. There would have been two identicle keys for the door and ignition. All these are missing for my '46, which is in the process of being restored. But, if the same as for the '37 the flat edge key is used for the ignition. | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Thanks for your input. It would make sense to have a separate key for the glove box so you could keep it locked when the door was not. Thanks again. None of my locks have keys so I will have to locate a lock smith. Any recommendations? Harold
Harold Is a restoration ever finished? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | One's hex and one's round on the end. You need B10 & B11 blanks. If you can't find a locksmith with those blanks on hand there are sellers on ebay with them. You can still get blanks with the same grooved ends as the B10 & B11 any place that sells keys but they aren't marked Briggs & Stratton or GM. They are usually gas cap keys.
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Tiny. Thanks, I forgot to ask about the key blanks. Harold
Harold Is a restoration ever finished? | | | | | Joined: Feb 2010 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 54 | It seems like there was a lock for the spare tire that used the same key as the glove box. A lock that fit over the bolt that holds the spare tire was usually lost after the first use. It may be hard to find one now.
Monroe McKill
