5 members (DadsFirstPickup, homer52, Otto Skorzeny, dt235sd, 2-Ton), 71 guests, and 3 robots.
Topics128,049
Posts1,055,661
#826401 02/15/2012 12:56 PM
I have a '53 3/4 ton with a transplanted engine #R 24359 UTAH. I've searched the numbers and I don't see an R or UTAH.
Ben
Possible reman stamp. Look for a cast number.
BC
1960 C60 pasture art
That most likely is a Utah assigned serial number on a replacement engine. Post the casting number.
I thought that was the casting number. It is stamped on the block to the left of the distributor.
3B Offline
Hy bens48bigbolt, casting numbers are raised above the surface, and are cast into/onto the block. Serial numbers or identification numbers are stamped into the surface with number or letter stamps, hope that helps.
Yes, thanks 3B
Hey Ben,
You'll find that block casting #
on the passenger side of the block.
Something like 3835911 or 3701946.
While you're there write down the other number,
it's the block casting date.
Will begin with a letter, like c124.
Post that info and we will tell you what you have.
-Tom
1950 Chevy 3100 w/ 1956 235
