| | | Forums66 Topics128,087 Posts1,056,372 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 9 New Guy | | New Guy Joined: Nov 2011 Posts: 9 | ok im having issues reassembling bed.... i bought this one already disassembled. so i will have many issues with reassembly. i have the assembly manual but does not show cross sill location... i have 3 cross sill 2 are the same size ( havent measured just eyeballed them) the other is a different looking one completely and i dont know if it goes in front or bad and really dont know what goes where as far as if blocks are needed and bolts needed as well. thank you for your time and i hope i can solve this problem quickly. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Have you attempted this yet? There should be bolt holes for the cross members. | | | | | Joined: Nov 2011 Posts: 9 New Guy | | New Guy Joined: Nov 2011 Posts: 9 | the issue is not the holes.... the issue is which crossmember goes where. as in there are 2 that are the same and 1 different. however after searching for a few day i have found a pic of a 57 bed and think i have it figured out. http://67-72chevytrucks.com/vboard/showthread.php?t=334552&page=2 | | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | Mine had indentation marks in the top of the frame where the cross stills sat... If you can not find any marks some one with a TF should be able to tell what the measurements are...You can find the bolt holes on the frame and lay the cross stills over them to see what they look like... Also, www.mar-k.com/index.aspx has the bed installation instructions...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
