6 members (tesa, RAC1812, Gdads51, Gray_Ghost, artinva, RdsLessTaken), 63 guests, and 0 robots.
Topics128,077
Posts1,055,928
Members48,430
#818913 01/23/2012 2:34 PM
wanting a truck to work with. Was thinking about doing a frame swap with a newer possible full size chevy.... that way could use brakes motor transmission not have to change anything other than body and stuff. I know alot uses s10 but was wondering if a full size chevy would work easier and which one to use..... I have someone offering me a 51 chevy free thanks and appreciate all ideas
Do as much research as you can. Keep trying, there are guys here that have done it. If you don't get any answers, bump your post with more questions..
Find out what you'll need for wheelbase width and length, and try to get your donor frame as close to it .
You should be able to Fabricate if your going that way, be ready to do a lot of it..
Options:
Use the original frame and fix it up
Use the original frame and add front and rear modern suspensions
Swap for an S10 frame
Swap for a full-size frame and do major mods to make the wheels fit.
Buy a pre-built frame designed for the AD truck
Any others?
Dakota frames are a better fit than the S-10, however I like a stock frame myself.
thanks
i started with the s-10 swap idea, purchased the ad kit then i changed my mind and went with original frame. if you are interested i will make you an awesome deal on the swap kit i purchased never used just bolted up for fabrication
I like the idea of using a more modern truck frame. . .what if you took a '80's or '90's frame and cut a section out of all the crossmembers, then welded them back together? You could achieve the proper track width on the front suspension, then get a rear axle to fit. The steering linkage would need some attention too. Anything I'm missing?
Craig
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
Get ready to do a HUGE amount of re-engineering. I've done the frame-narrowing thing on a few round track race cars, and it's never as simple as a bull session around a case of beer makes it sound. You'll encounter major changes in steering geometry caused by changing roll centers and Ackerman angle changes affecting the toe-out in turns. You'll end up with a pretty good straight-line machine that will have totally unpredictable handling in turns. You'll also have to completely redesign the motor mount system.
