3 members (rfs56trk, Otto Skorzeny, Cletus1950), 115 guests, and 2 robots.
Topics128,128
Posts1,056,666
Members48,450
#826233 02/14/2012 9:17 PM
Big Bolt Forum Co-moderator
I am stripping out the interior of my 48 cab. It looks like the center brace that runs across the underside of the roof needs to be removed for prepping and looks to be spot welded on the ends above the door jambs. Does everyone take that off, or do you just clean it up as best you can between the brace and the underside of the rood? I hate to take it off if it isn't necessary.
1948 Chevy 2-Ton
Are you talking about the brace across the top of the windshield?
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
-Unknown-
I believe he's referring to the center bow for the headliner.
On my 50 it floats
His 48 is tacked in place
DADS50 #826673 02/16/2012 2:38 AM
Yep.. the tacked one.
1948 Chevy 2-Ton
