| | | Forums66 Topics128,022 Posts1,055,360 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 292 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 292 | will a 93 silverado brake booster and master cylinder work on my 51 3100 | | | | | Joined: Dec 2009 Posts: 292 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 292 | will a 93 silverado power booster and brake pedal work on my 51 3100
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Not without a lot of modification. The 93 has disk brakes, the 53 doesn't,unless the brake system was changed.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Just buy an aftermarket booster. Bolt it on and go. Mine is drum/drum and works great. | | | | | Joined: Dec 2009 Posts: 292 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 292 | thanks guys. can i use the booster and pedal change the master cylinder to a drum drum
| | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | The brake system is one of the places that you just CANNOT take any chances! I would say , "Sure," it can be done, but is it worth the trouble? The fluid tanks are different sizes and have different valving. In my opinion, you'd have to add front discs and replumb a good bit of your brake system to make it useful. I don't believe the original master will work with just the booster and I was thinking about the combo. The '51 master is under the floor so you need to be careful, there, that the booster will fit. There is a lot more than one would think to swapping pedals from bottom pivot to top pivot, however, if you can get everything and a piece of firewall from the '93 it is worth considering. Skill level, availability, time, and cost should ALL be considered before jumping into something like this! Keep us posted!
best wishes,
Les | | | | | Joined: Feb 2009 Posts: 269 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 269 | Gents, I have to agree with Les, I have been following this thread because I am about to embark on setting up my brake system from scratch. I have been doing a lot of reading and making sure that I have all the components needed so when it is time to start plumbing, I do not have to stop and wait for a part. Something doesn't seem right to me. Here is what I found and has lead me to get a adjustable proportional valve and a residual valve. I also received the brake line kit from TCI yesterday and on the diagram, it shows that I need the valves. Too bad they didn't come with the kit. From Hotrodheaven Brake article by Dean Oshiro Hope isn't a strategy when it come to brakes. Bread | | | | | Joined: Dec 2009 Posts: 292 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 292 | im going to do a firewall mount and wondered if i could mount the booster and change the master to a 1970s.i curently have no brake line so i will have to run all new.
John | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | @johns truck, Ok, here's what I would do, find a vehicle that weighs approximately the same as my truck that uses a disk/drum set-up. Get the master-booster combo or buy it new. See what size lines it uses, probably 1/4" front and 3/16" rear. Get the disk brake set-up for the front and whatever new parts for the rear. Get the underdash pedal assembly and a big piece of the firewall. Don't forget the supports for the pedals and the brake light switch. Find or order a new rear rubber line. Now you have enough parts to begin the conversion. I'm sure you have a GOOD brake line flareing tool, 'cause you're going to need it. The lines are cheap; $3 to $5 each, but you'll probably need a couple of adapters in the rear. You get the picture. It is worth doing yourself, but no place to take short cuts! Be careful, you might have it pointed at ME if the brakes fail!
best wishes,
Les | | | | | Joined: Dec 2009 Posts: 292 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 292 | ok will keep you posted. trust me im not going to short cut on the breaks just trying to do it on a tight budget.
John | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Check this out; www.hotrodheaven.com/tech/brakes/brakes4.htmIt is pretty technical, but it explains how big of a resevoir you need, pedal stroke, and lots of other stuff.
