1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#826642 02/16/2012 1:30 AM
will a 93 silverado brake booster and master cylinder work on my 51 3100
#826653 02/16/2012 2:00 AM
will a 93 silverado power booster and brake pedal work on my 51 3100
Not without a lot of modification.
The 93 has disk brakes, the 53 doesn't,unless the brake system was changed.
Tommy
59 apache 1/2t
261 short stepside
Tommy #826919 02/16/2012 9:53 PM
Just buy an aftermarket booster. Bolt it on and go. Mine is drum/drum and works great.
jomichael #826945 02/16/2012 11:01 PM
thanks guys. can i use the booster and pedal change the master cylinder to a drum drum
The brake system is one of the places that you just CANNOT take any chances! I would say , "Sure," it can be done, but is it worth the trouble? The fluid tanks are different sizes and have different valving. In my opinion, you'd have to add front discs and replumb a good bit of your brake system to make it useful. I don't believe the original master will work with just the booster and I was thinking about the combo. The '51 master is under the floor so you need to be careful, there, that the booster will fit. There is a lot more than one would think to swapping pedals from bottom pivot to top pivot, however, if you can get everything and a piece of firewall from the '93 it is worth considering. Skill level, availability, time, and cost should ALL be considered before jumping into something like this! Keep us posted!
best wishes,
Les
Gents,
I have to agree with Les, I have been following this thread because I am about to embark on setting up my brake system from scratch. I have been doing a lot of reading and making sure that I have all the components needed so when it is time to start plumbing, I do not have to stop and wait for a part. Something doesn't seem right to me. Here is what I found and has lead me to get a adjustable proportional valve and a residual valve.
I also received the brake line kit from TCI yesterday and on the diagram, it shows that I need the valves. Too bad they didn't come with the kit.
From Hotrodheaven
Brake article by Dean Oshiro
Hope isn't a strategy when it come to brakes.
Bread
1939 Chevrolet 1/2-Ton
"There and back -- repeat"
Bread #828281 02/21/2012 1:52 AM
im going to do a firewall mount and wondered if i could mount the booster and change the master to a 1970s.i curently have no brake line so i will have to run all new.
@johns truck, Ok, here's what I would do, find a vehicle that weighs approximately the same as my truck that uses a disk/drum set-up. Get the master-booster combo or buy it new. See what size lines it uses, probably 1/4" front and 3/16" rear. Get the disk brake set-up for the front and whatever new parts for the rear. Get the underdash pedal assembly and a big piece of the firewall. Don't forget the supports for the pedals and the brake light switch. Find or order a new rear rubber line. Now you have enough parts to begin the conversion. I'm sure you have a GOOD brake line flareing tool, 'cause you're going to need it. The lines are cheap; $3 to $5 each, but you'll probably need a couple of adapters in the rear. You get the picture. It is worth doing yourself, but no place to take short cuts! Be careful, you might have it pointed at ME if the brakes fail!
best wishes,
Les
Roadmarks #828581 02/21/2012 11:21 PM
ok will keep you posted. trust me im not going to short cut on the breaks just trying to do it on a tight budget.
Check this out; www.hotrodheaven.com/tech/brakes/brakes4.htm
It is pretty technical, but it explains how big of a resevoir you need, pedal stroke, and lots of other stuff.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
