| | | Forums66 Topics128,031 Posts1,055,436 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 103 | I have a '53 3/4 ton with a transplanted engine #R 24359 UTAH. I've searched the numbers and I don't see an R or UTAH. Thanks, Ben | | | | | Joined: Sep 2011 Posts: 1,451 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,451 | Possible reman stamp. Look for a cast number.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | That most likely is a Utah assigned serial number on a replacement engine. Post the casting number. | | | | | Joined: Nov 2011 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 103 | I thought that was the casting number. It is stamped on the block to the left of the distributor. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy bens48bigbolt, casting numbers are raised above the surface, and are cast into/onto the block. Serial numbers or identification numbers are stamped into the surface with number or letter stamps, hope that helps. | | | | | Joined: Nov 2011 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 103 | | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | Hey Ben,
You'll find that block casting # on the passenger side of the block. Something like 3835911 or 3701946.
While you're there write down the other number, it's the block casting date. Will begin with a letter, like c124.
Post that info and we will tell you what you have.
-Tom
1950 Chevy 3100 w/ 1956 235
