| | | Forums66 Topics128,087 Posts1,055,974 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I just got my LMC catalog yesterday and they are now selling 8 LUG WHEELS for trucks. They have three varieties, all with the old traditional hole pattern. Now somebody needs to contact them to find out what the offset is.
Speaking of news, I see that the "new front AD fenders made of steel" have disappeared from their catalog and I can't find them in Jim Carter's any longer. I wonder what is up with that? | | | | | Joined: Jul 2004 Posts: 102 Member | | Member Joined: Jul 2004 Posts: 102 | Are these the wheels that fit 3/4 ton trucks?  And what is LMC?
1948 3600 thriftmaster
| | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | LMC is a parts supplier. Go to home page, click on "links" then on "parts". Good list.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | just called lmc and asked about their wheels. they go up to 16x8, no 17 in.
tony'n weatherford | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | LMC: Long Motor Corporation. Also home to Victoria British Car Parts (handy for me). Give them your address and they will mail you a catalogue free. Has neatinfo like VIN decode, differences year-to-year, etc. I use it for the diagrams, helps explain the shop manual.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Nov 2004 Posts: 328 Member | | Member Joined: Nov 2004 Posts: 328 | I was a dealer for them a while ago. They don't have the fenders anymore because "they have decided to stop producing them." YEA RIGHT. I called them to order some, and they told me that. NO ONE is selling them, all I can find is fiberglass. Good luck with the wheels, I've seen them and they look pretty good. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Tony N the difficult part of getting modern rims for an AD 3/4 or 1 Ton is the backset of the rim. That can't be any more than 3 1/2" in most cases. They are 16" rims, not 17" but they do show 16.5" rims. 16.5" is an odd size of tire which I think is going to disappear. | | |
#8257 02/06/2005 12:46 AM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | If the rims are 16x8, they might be too wide for the AD 3/4T front regardless of the setback. I have some 16x6 rims which handle my 235-85-R16 tires on the front. I think they sit as high as the original tires on the 17" rims. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Wally, that is what I have been thinking. I am curious if even the backset is OK. | | | | | Joined: Feb 2002 Posts: 75 Member | | Member Joined: Feb 2002 Posts: 75 | but...........are trailer wheels ok to use on a truck???????
'53 chevy 3/4 ton
| | | | | Joined: Sep 2004 Posts: 148 Member | | Member Joined: Sep 2004 Posts: 148 | i used 16x7 on my 59 1-ton (TF) with a zero offset. 3.5" backspace, no problems with clearance. they will be for sale soon (but not yet), i am switching to 5 lug wheels when i clip the front, and change the rearend
2003 ford lightning 1959 chevy 36
