5 members (rfs56trk, Gdads51, 2-Ton, 78buckshot, 1 invisible), 180 guests, and 4 robots.
Topics128,078
Posts1,056,024
Members48,433
NEED help, 216 water pump markings,confused,Babe ,NEW gUY
what exactly would you like to know?
1951 Chevy 3100
Some days you get the bear. Some days the bear gets you.
Here are a couple of pictures of the water pumps from my 1950 216 which would be the
same as your ‘53 Vince.
An original 839467 216 water pump, 839403 casting number:
http://www.pbase.com/dennygraham/image/141420919/large
A replacement 216 water pump:
http://www.pbase.com/dennygraham/image/141420923/large
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
DENNY, THE WATER PUMP THAT I TOOK OFF MY 1953 ,216 ENGINE HAS THE SAME PART NUMBER 839403 ,HOWEVER IT HAS GM33 ISTEAD OF GM7.I ORDERED A REBUILT GM AND IT CAME WITH THE NUMBER GM7 JUST LIKE THE ONE YOU SHOW,DO YOU KNOW WHY THE DIFFERENT #S ALTHOUGH SAME PART #?THANK YOU,VINCE
Denny or somebody will probably respond soon. But I think the GM33 or GM7 identifies the casting plant where the pump housing was cast...as GM had many factories making parts, etc.
Professional Novice
Can't say for sure, but that would be my guess also since the raised number is a casting number.
Here are the head casting numbers of a couple of our members, you can clearly see
the GM5 and GM14 numbers on them also.
http://www.pbase.com/dennygraham/image/141472974
http://www.pbase.com/dennygraham/image/141472975
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Save yourself a lot of trouble & buy one from NAPA.
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?R=WP_58125_0333182216
It comes with a LIFETIME WARRANTY.
Verify this part number but I believe it also fits your 1953.
Harold
Harold
Thanks, Harold. That 5/8" groove pump will work for several years (Jim Carter says 1941-52).
I do not know if 1953 used the 5/8" or the 3/8" pulley-groove. NAPA says 5/8" for 1953.
NAPA also has the 54/55 3/8" groove water pump for a little higher price, ~$69.00 plus core.
Here is the warranty information (just save the receipt):
REMEDY and SERVICE
A replacement for a failed or defective NAPA Water Pump is available from the point of purchase.
The unit must be returned with proof of purchase and a written description of the failure or
defect.
Except for big trucks, 1953-54 and 55 first, used a 3/8" belt
My Blog
Tim,
According to the Chevrolet Master Parts Catalog, 53-54 used the 3/8" pulley.
http://chevy.oldcarmanualproject.com/1929_54chevyparts/01/119.HTM 7th from top on the left.
Harold
Harold
Denny,here is another 1956 car 235 head I have.It has a GM19 on it and I have seen them with GM28,it's probably a date code.
1956 car 235 head casting #3836848 GM19
Tim
1951 3100 Chevrolet
Thanks Tim, we just don't know do we. But with all the numbers that are showing up it
doesn't seem possible that there would be that many casting plants so you may be right
about it being a date code. The 913 head on my '54 is coded GM10, so yet another.
But, we better watch it, for fear that we veer to far off subject and the thread Nazi's jump
on our case.
DG
Denny G
Sandwich, IL
I do not think that is a date casting code. Here is the location of the date casting code.
Do you have a code in that location?
You'll see that code on the right of this photo.
That GM10, GMXX code might be related to the "line" in the casting foundry? Someone at the VCCA discussion board should know?
Could it be a batch number ? or a mold number ?
Tim
1951 3100 Chevrolet
Could have a variety of possible meanings, except it is not a date casting code. A VCCA expert would be the best bet for an explanation.
I wouldn't mind knowing what those GMxx numbers were because
they are on a lot of the castings that we see on the truck
parts. But, some of you know the relationship I have with the
VCCA so it's going to have to be up to someone else to dig that
out of them.
DG
Denny G
Sandwich, IL
everybody, thank you for the help.I HAVE FOUND NAPA WAS THE CLOSEST TO ORIGINAL ,WRONG PULLY SIZE THEY ARE REORDERING TOMORROW I WILL LET YOU KKOW THANKS AGAIN BABE
