0 members (), 348 guests, and 6 robots.
Topics128,162
Posts1,057,042
Members48,463
So I'm going to replace the entire wiring system in my truck. I have the new direct replacement harness coming to me in the mail. The new harness kit did not come with a new Fuse Block, so I bought this one from Bob's Chevy Truck. It looks to have a lot more circuits on it for using radio, heater etc... unfortunately it did not come with instructions.
I extensively looked online for the instructions and found none. I did however turn up pictures of this exact same fuse block with the instructions half covered up by the fuse block. So now I know that instructions ARE supposed to come with this fuse block, mine for some reason just didn't. I do have a color coded siring diagram that I bought online, and in using that I fitted the supplied wires to it. Is this right? Has anyone else used the fuse block and have the instructions?
http://i1236.photobucket.com/albums/ff441/AZ59apacheguy/beed7a2f.jpg
that's close to the original accessory TF fuse block, labels are all the instruction you should need with a factory harness and factory wiring diagram ... the fuse block was only originally installed if there were accessories installed like the labels call out, and the small wiring sections for each accessory were separate from the main harness, just the wires needed to reach each item from the clip on tab terminals .... the 3 wires you have on there are all to supply power to the block
the red wire should go to the light switch BATT terminal, that's for 'always on' power .... the gray wire goes to the PL terminal of the light sw to supply power when the dash [panel] lights are on for things like the glove box light .... the pink wire goes to the ACC terminal on the ignition sw, gets power only when the key is on
note that the ACC LP position [gray] doesn't involve a fuse, the panel lamp fuse is the small one on the light switch so that terminal just acts as a junction point
some fuse values:
backup - 9a
heater - 9a
fog - 14a
park brake alarm - 9a
radio - 7.5a
spot lp - 9a
under hood lp - 9a
i used this part and it is just as Bill says. Hook up the 3 wires (gray, red, pink) to the truck to bring power to the fuse panel, then wire up your accessories. i hooked up my electric wipers, radio, glovebox lamp, heater blower, and cigar lighter to it.
acc fuse panel
Thanks for all the replies. And I really appreciate the fuse values red58 and the pic tomctomc
