0 members (),
118
Mod | | | Forums66 Topics128,186 Posts1,057,320 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2001 Posts: 36 | I want to do a light sanding on the interior of my 65 and repaint. What I need to know is what was the original paint type. I've heard that there can be problems if you paint lacquer over enamel or the other way around. I'd like to stick with the original type of paint used. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | interiors were lacquer way back, but by 65 they likely used enamel - either way, the decades it's been on there should make it no problem, but you should test some covered spot to check - see here .... enamel will hold up better Bill | | | | | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | You can put enamel over lacquer, but not lacquer over enamel, at least without a few coats of sealer. Lacquer will blush if it's too humid, it will orange peal if it's too hot, it will take lots of coats with a chance of every one of them to screw it up, and etc. etc.. I would not even think of painting lacquer. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Per the Truck Sales Data Books, "Chevrolet trucks are finished with Dulux 100 enamel which has excellent color and gloss retension for easy maintenance and high durability. After the application of a prime coat, all bodies and sheet metal are given two coats of high-luster enamel." "One of the most oustanding characteristics of the Dulux 100 enamel is its exceptional color and gloss retention, even after prolonged weathering." | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Go with a 2 part polyurethane. It has great depth and is fairly easy to work with. And is not much more $ than enamel.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
