10 members (68ironhead, Wally / Montana, 3B, Gdads51, Bill Hanlon, Gray_Ghost, Rusted Nut, Shade Baby, Pre '68 Dave, Otto Skorzeny), 162 guests, and 1 robot.
Topics128,104
Posts1,056,197
Members48,436
Big Bolt Forum Co-moderator
Just wanted to post this to remind people about the tech tips. I sort of forget about it sometime. The reason I went there today was to figure out how to take off the ignition switch.
No where in the manual does it tell you how to get the key cylinder out so you remove the switch. So I did a search and there was one post that came up that lead me to the tech tips.
Also, the light switch needed to come out. Could not see for the life of me how to take off the switch and I am getting cautious in my old age. Sure I found it here when I did a search. It wasn't in tech tips, but maybe it should be. Who knew there was a button on the side of the switch to remove the center rod. Awesome.
1948 Chevy 2-Ton
TClederman,
Hahaahahaa I guess I got lazy and scoped the site before looking in the manual for the light switch. It was so helpful on the key switch. Is there a spot in the manual that shows how to take out the key cylinder in the ignition?
1948 Chevy 2-Ton
Super55,
It is hard to remember what can be found in the Shop Manual, the Owners Manual, and in the illustrations in the Master Parts Book.
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm1226.htm
I'll be trying this later. The 48 I'm working on doesn't have a key though (I'll try another GM key I have). I can turn the ignition switch from the right (off) to vertical (on) only. Do these ignition switches go to the left also?
Yes, they do, but you'll need the key for that. It's the "lock" position.
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
I found a lock for the door for my 49 in the parts that came with the truck no keys so I took the lock to a lock smith and they found the code for the key which is on the lock and they made a key from that code and it worked. It also worked for the glove box. What a find.
Thanks Tom. Kind of what I thought.
Later,Bill
