2 members (Hugh63c10, Phak1),
260
Mod | | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 16 New Guy | | New Guy Joined: Apr 2011 Posts: 16 | NEED help, 216 water pump markings,confused,Babe ,NEW gUY | | | | | Joined: Sep 2003 Posts: 200 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 200 | what exactly would you like to know?
1951 Chevy 3100 Some days you get the bear. Some days the bear gets you.
| | | | | Joined: Apr 2011 Posts: 16 New Guy | | New Guy Joined: Apr 2011 Posts: 16 | DENNY, THE WATER PUMP THAT I TOOK OFF MY 1953 ,216 ENGINE HAS THE SAME PART NUMBER 839403 ,HOWEVER IT HAS GM33 ISTEAD OF GM7.I ORDERED A REBUILT GM AND IT CAME WITH THE NUMBER GM7 JUST LIKE THE ONE YOU SHOW,DO YOU KNOW WHY THE DIFFERENT #S ALTHOUGH SAME PART #?THANK YOU,VINCE | | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | Denny or somebody will probably respond soon. But I think the GM33 or GM7 identifies the casting plant where the pump housing was cast...as GM had many factories making parts, etc.
Professional Novice
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Can't say for sure, but that would be my guess also since the raised number is a casting number. Here are the head casting numbers of a couple of our members, you can clearly see the GM5 and GM14 numbers on them also. http://www.pbase.com/dennygraham/image/141472974 http://www.pbase.com/dennygraham/image/141472975 Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks, Harold. That 5/8" groove pump will work for several years (Jim Carter says 1941-52).
I do not know if 1953 used the 5/8" or the 3/8" pulley-groove. NAPA says 5/8" for 1953.
NAPA also has the 54/55 3/8" groove water pump for a little higher price, ~$69.00 plus core.
Here is the warranty information (just save the receipt):
REMEDY and SERVICE A replacement for a failed or defective NAPA Water Pump is available from the point of purchase. The unit must be returned with proof of purchase and a written description of the failure or defect.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Except for big trucks, 1953-54 and 55 first, used a 3/8" belt
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Denny,here is another 1956 car 235 head I have.It has a GM19 on it and I have seen them with GM28,it's probably a date code. 1956 car 235 head casting #3836848 GM19 Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thanks Tim, we just don't know do we. But with all the numbers that are showing up it doesn't seem possible that there would be that many casting plants so you may be right about it being a date code. The 913 head on my '54 is coded GM10, so yet another.
But, we better watch it, for fear that we veer to far off subject and the thread Nazi's jump on our case.
DG
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Could it be a batch number ? or a mold number ?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Could have a variety of possible meanings, except it is not a date casting code. A VCCA expert would be the best bet for an explanation.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I wouldn't mind knowing what those GMxx numbers were because they are on a lot of the castings that we see on the truck parts. But, some of you know the relationship I have with the VCCA so it's going to have to be up to someone else to dig that out of them.
DG
| | | | | Joined: Apr 2011 Posts: 16 New Guy | | New Guy Joined: Apr 2011 Posts: 16 | everybody, thank you for the help.I HAVE FOUND NAPA WAS THE CLOSEST TO ORIGINAL ,WRONG PULLY SIZE THEY ARE REORDERING TOMORROW I WILL LET YOU KKOW THANKS AGAIN BABE | | |
