5 members (texas46, Jaison, Hotrod Lincoln, JW51, WICruiser), 148 guests, and 3 robots.
Topics128,082
Posts1,055,961
Members48,430
#8250 02/05/2005 3:12 PM
I just got my LMC catalog yesterday and they are now selling 8 LUG WHEELS for trucks. They have three varieties, all with the old traditional hole pattern. Now somebody needs to contact them to find out what the offset is.
Speaking of news, I see that the "new front AD fenders made of steel" have disappeared from their catalog and I can't find them in Jim Carter's any longer. I wonder what is up with that?
1951 1 Ton Completed
#8251 02/05/2005 3:24 PM
Are these the wheels that fit 3/4 ton trucks? eek And what is LMC?
1948 3600 thriftmaster
#8252 02/05/2005 3:51 PM
LMC is a parts supplier. Go to home page, click on "links" then on "parts". Good list.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
#8253 02/05/2005 5:14 PM
Anonymous
Unregistered
Anonymous
Unregistered
just called lmc and asked about their wheels. they go up to 16x8, no 17 in.
tony'n weatherford
#8254 02/05/2005 5:14 PM
LMC: Long Motor Corporation. Also home to Victoria British Car Parts (handy for me). Give them your address and they will mail you a catalogue free. Has neatinfo like VIN decode, differences year-to-year, etc. I use it for the diagrams, helps explain the shop manual.
#8255 02/05/2005 5:25 PM
I was a dealer for them a while ago. They don't have the fenders anymore because "they have decided to stop producing them." YEA RIGHT. I called them to order some, and they told me that. NO ONE is selling them, all I can find is fiberglass. Good luck with the wheels, I've seen them and they look pretty good.
GO RANGERS grin
Photos Updated so check them out!
#8256 02/05/2005 7:07 PM
Tony N
the difficult part of getting modern rims for an AD 3/4 or 1 Ton is the backset of the rim. That can't be any more than 3 1/2" in most cases. They are 16" rims, not 17" but they do show 16.5" rims. 16.5" is an odd size of tire which I think is going to disappear.
#8257 02/06/2005 12:46 AM
If the rims are 16x8, they might be too wide for the AD 3/4T front regardless of the setback. I have some 16x6 rims which handle my 235-85-R16 tires on the front. I think they sit as high as the original tires on the 17" rims.
#8258 02/06/2005 3:07 AM
Wally,
that is what I have been thinking. I am curious if even the backset is OK.
#8259 02/06/2005 3:27 AM
OK, I did a little digging. Have a look at this list and you will see a white spoked wheel, 16 x 6 with 8 lugs and zero offset. That would put the backset at 3".
http://www.lowcosttrailersupplies.c...mp;Store_Code=LCTS&Category_Code=WSW
Does that make sense?
#8260 02/09/2005 2:21 AM
but...........are trailer wheels ok to use on a truck???????
'53 chevy 3/4 ton
#8261 02/09/2005 3:08 PM
1 Offline
i used 16x7 on my 59 1-ton (TF) with a zero offset. 3.5" backspace, no problems with clearance. they will be for sale soon (but not yet), i am switching to 5 lug wheels when i clip the front, and change the rearend
2003 ford lightning
1959 chevy 36
