5 members (Rusty Heaps, Hambone, 3B, Gray_Ghost, Joe H), 223 guests, and 3 robots.
Topics128,151
Posts1,057,009
Members48,460
I
I Offline
Is there a cast iron bell housing that fits an NV4500 to a 292?
I'm considering putting a 292 in my 1940 3/4 ton but want to keep the original clutch and brake pedals.
3B Online: Content
3 Online: Content
Hy InMy40s, I think if you use a NV4500 originaly designed for a Dodge application then you need a one inch thick adapter, with that adapter you could make the trans fit and use the stock bellhousing, hope that helps.
50 chevy 3100
Greg,
I'm sure you are aware the 292 is the same as a sbc or bbc when it comes to bellhousings. Gm used an NV4500 on their trucks in the 90s, so there are bellhousings that will bolt up to both the 292 and the gm NV4500.
The 1955 and later v8 bellhousings, will bolt up to your 292, but you will need to modify the crossmember to accept the angled mounts. 1940 bellhousings have provisions to mount the clutch and brake pedals, 1955 and later bellhousings do not.
When gm used the NV4500 in there trucks, the bellhousing did not bolt to a crossmember. The motor used 2 front side mounts, and 1 tail support on the transmission. The side mounts should not be a problem to fabricate, but losing the bellhousing crossmember may give you some problems in your 1940.
I would consider using a stovebolt to th350 adapter turned around to bolt the 292 to the 1940 stovebolt bellhousing. You would likely have to make your own adapter to run the nv4500 behind the stovebolt bellhousing. I made an adapter for my 1940, but still haven't gotten around to working on that truck. I can send pics on request. By the way, thanks for the brake pedal stuff from that 1.5 ton gmc
3B Online: Content
3 Online: Content
Hy InMy40s, I guess I was sleep typing last night, as bigbadswingdaddy said, you would need an adapter to use your original bellhousing with pedal mounts and correct engine mounts, and then the other adapter to mount the transmission.
I
I Offline
I wasn't planning on using the original bell housing. I was looking for a cast iron bell housing and have Buffalo weld on the brake and clutch mount. I was hoping there was one that had the bolt pattern for an NV4500.
Perhaps the Advanced Adapter plate is the best route. That way I could easily put in the transmission cross member
If you use the AA plate, you will need a 1969 and later truck bellhousing with the 5.125 bore. You could use an earlier bellhousing with the 4.686 bore and hog it out to 5.125 inches, or have the indexing ring on the adapter plate turned down on a lathe to 4.686 inches.
I have an NV4500 in my 1959 gmc, and another ready to go in my 1940. The homemade adapter for my 1940 should fit your 1940 if you wanted to dry fit the NV4500 before swapping engines.
There is a rare bell housing used on early versions of the RPO MY6. That has both the Chev and Dodge (A833 trans) bolt patterns. I don't know that the A833 bolt pattern and NV4500 are the same. The MY6 was used from 82-86, so the bell housing I'm guessing would be about an 82.
Larry
I don't own a vehicle that isn't old enough to drink.
I
I Offline
Hey John,
Thanks for the offer.
I just picked up the 292 last weekend and don't have an NV4500 yet. I'm thinking it's the best bet behind the 292. I put a T5 behind a 235 in my 46 but I think a T5 would be too light behind the 292. I plan on hoping the 292 up a bit which should put out around 275-300hp.
bigbadswingdaddy is right on the money! All you need to find is a standard transmission bellhousing from one of those years and its a bolt up except the drive shaft. Remember, too, that you MUST use the correct fluid in your NV4500, Castrol SYNTORQ. NOTHING else will work correctly. Get it from Chevy or Dodge dealers for about $28.00/QT! It takes 4!
I use AMSoil in mine. It still comes out to about $100 to fill it.
Best to buy a NV4500 from 1993-95 Chevy/GMC 3500 with the bell housing. Everything will bolt up to 292.
You still have to deal with Hydro. slave cylinder for clutch, but there are a couple good sites to walk you through that.
I have same setup going in my 3800...have been working on motorcycles, hope to get back to the 3800 SOON...See pics of NV4500 in my album.
1954 4400
1954 3800
Jim D.
'41 Chevy 1-Ton Pickup/dump...292" 4-speed w/Ranger OD ... Newest Truck
'54 Chevy 3800 Dump........New Truck!
'54 Chevy 4400 flatbed/dump, Gone to my brother-in-law
'13 GMC 1500 daily driver ... 5.3 6-speed auto just turned 13k miles
'01 Chevy 2500hd, might be my new daily driver ... 6.0 / 4L80-E
"Best to buy a NV4500 from 1993-95 Chevy/GMC 3500 with the bell housing. Everything will bolt up to 292."
What about the mechanical speedometer. The gm version is set up for a velocity sensor. The early dodge nv4500 has a pulse generator that can easily be pulled out to make room for a traditional speedo pinion. There are plenty of charts published on the internet that tell you which speedo pinion is needed for the differential/ tire combination.
