3 members (GIJOE298, Peggy M, 1 invisible),
123
Mod | | | Forums66 Topics128,078 Posts1,056,056 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#82455 09/03/2007 4:25 PM | Joined: Apr 2007 Posts: 48 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 48 | Hi ALL, I'm replacing the rocker arms on my 1958 235 motor and have a question; Can I just replace the rocker assembly without changing the clearances, and then recheck the clearances after the motor is restarted and warmed up? Thanks for your advise....Richard | | |
#82456 09/03/2007 4:42 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | bebop40,
Probably not. You can do a COLD adjustment if you add .005 to the specs. After some run-in, go back and set them using a warm motor and the HOT values.
EDIT. The above procedure applies to solid lifters...not hydraulic lifters, I don't know what a '58 engine would have.
Stuart | | |
