7 members (NJC, Gray_Ghost, GMCJammer51, Greg_H, 50Chevy3100, 1955 1 Series, 1 invisible), 74 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#82455 09/03/2007 4:25 PM
Hi ALL, I'm replacing the rocker arms on my 1958 235 motor and have a question; Can I just replace the rocker assembly without changing the clearances, and then recheck the clearances after the motor is restarted and warmed up? Thanks for your advise....Richard
#82456 09/03/2007 4:42 PM
bebop40,
Probably not. You can do a COLD adjustment if you add .005 to the specs. After some run-in, go back and set them using a warm motor and the HOT values.
EDIT. The above procedure applies to solid lifters...not hydraulic lifters, I don't know what a '58 engine would have.
Stuart
