| | | Forums66 Topics128,135 Posts1,056,423 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 15 New Guy | | New Guy Joined: Feb 2012 Posts: 15 | Ok, whats the trick to installing a new gas tank neck filler grommet on a 54 GMC Truck! how hard can it be!!
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Are you first putting the grommet into the body opening, and then running the filler tube through the installed grommet?
| | | | | Joined: Feb 2012 Posts: 15 New Guy | | New Guy Joined: Feb 2012 Posts: 15 | I tried to get the neck out but it will not budge from the hoses even though i took the clamps off. The entire inside hoses and neck appear brand new. wow! thanks for any advice. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you won't get the grommet over the outer wide part of the fill neck .... those hoses inside are special fuel resistant parts and quite tough - need to grab each end one at a time with some pliers and work them a bit to break loose before the filler will come out, still with effort
Bill | | | | | Joined: Feb 2012 Posts: 15 New Guy | | New Guy Joined: Feb 2012 Posts: 15 | Thanks Red58, I appreciate the help. I will get my high blood pressure pants on and commence to pulling. I was thinking of using a little soap on them hoses to try and persuade them but think they are more water tight than a submarine. NASA could learn a lot from them hoses!! | | |
