4 members (Patharr, Gdads51, Shade Baby, DadsFirstPickup), 96 guests, and 1 robot.
Topics128,119
Posts1,056,311
Members48,439
#823975 02/08/2012 3:28 AM
can i drill out a 235 head for the three sets of steam holes that will match the steam holes that are in the engine block, I just realized while replacing my head gasket that the head I have used is a 235 without the steam holes and my engine is a 261, should I be concerned about the lack of steam holes?
thanks
jeff
Yes you can but as I recall it's a tricky job. There was an article on the Stovebolt about doing this but I can't find it. Hopefully somebody else can find it.
Bruce
My Trucks
Stuff I Collect
I had my machine shop drill mine using the original 261 head gasket as a template.
Tim
1951 3100 Chevrolet
The holes need to be drilled at a slight angle to make sure they intersect the proper cooling passage. Straight drilling only allows about half the diameter of some of the holes to flow coolant.
I drilled my own using the head gasket as a template. No problems.
don
Hi Jeff,
I also drilled out a 235 head using the 261 head gasket as a template.
I used a titanium bit in my hand drill and it cut through very easily.
I think the bit size was 3/16" but it's been a while. You can measure the block hole size.
As Jerry mentioned, check the passages for any angle you might have to make to intersect.
The critical point is the surface location to assure the hole opening will meet the gasket and consequently, the block holes.
Keep aware of the gasket combustion seal area. The holes are CLOSE and you DON'T want to get into that!
Some people opt to not drill and just let the head cap off the holes in the block... I think that's a mistake.
This 261 bad boy needs to be cooled by design.
Just my 2 cents...
Good luck!
Jerry W.
You Tube
