| | | Forums66 Topics128,165 Posts1,057,011 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | First question: The rear main seal for the 1960 261 cu. in. motor is shown in the manual as a rope seal, Is there a neoprene seal available or will I need to get another rope seal?
Second: external gaskets, In particular the valve cover,lifter gallery, and oilpan, are these gaskets the same size as the 235 cu. in. motor or specific to the 261?
-Mike-
1945 Chevrolet G 506 1.5 Ton Military 4X4 1967 Jeep Cj5 with 283 SBC
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | There should be a neoprene seal available for that engine. Your local parts store shouldn't have any problems getting one. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Mike,
First question: I think I used the neoprene seal on my 1960 261 (both styles of seals came in the gasket set). Wait to hear a confirmation that this is possible/correct.
Second question: yes, same-year 235s and 261 would use the same external gaskets (except, maybe, the thermostat gasket).
