2 members (Gdads51, Guitplayer), 76 guests, and 3 robots.
Topics128,162
Posts1,056,950
Members48,458
First question: The rear main seal for the 1960 261 cu. in. motor is shown in the manual as a rope seal, Is there a neoprene seal available or will I need to get another rope seal?
Second: external gaskets, In particular the valve cover,lifter gallery, and oilpan, are these gaskets the same size as the 235 cu. in. motor or specific to the 261?
-Mike-
1945 Chevrolet G 506 1.5 Ton Military 4X4
1967 Jeep Cj5 with 283 SBC
There should be a neoprene seal available for that engine. Your local parts store shouldn't have any problems getting one.
Mike,
First question: I think I used the neoprene seal on my 1960 261 (both styles of seals came in the gasket set). Wait to hear a confirmation that this is possible/correct.
Second question: yes, same-year 235s and 261 would use the same external gaskets (except, maybe, the thermostat gasket).
