| | | Forums66 Topics128,108 Posts1,056,227 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 4 New Guy | | New Guy Joined: Nov 2011 Posts: 4 | So I have figured out my truck is most likely a 1942 1/2 ton. There appears to be a hand-made VIN stamped on the frame with 1942 stamped underneath it. The actual VIN number appears to have been assigned at some point to register the vehicle in the past. The original serial number is missing and I have no title. I am having trouble getting it registered, New Mexico pretty much says I am out of luck.
So I thought about using a titled chassis, perhaps an S-10 and swapping the body over. I want a cool looking daily driver and not so much interested in a total restoration. Well, I have come across a free '96 S-10 but it is a 4x4, could I swap my '42 body over on top of the 4x4 chassis?
Thanks, Rob
"He was a wise man who invented beer." -Plato
| | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | Sure you can. May take some cyphering, but it can be done. If that's what you want. But, I think you will still have trouble titling it with an S10 title as the title 'sposed to go with the body, not the frame... I suggest you ask NM DMV what your options are. Good luck.
Professional Novice
| | | | | Joined: Nov 2011 Posts: 4 New Guy | | New Guy Joined: Nov 2011 Posts: 4 | In NM I can title it as a reconstructed vehicle using the chassis as the primary VIN. I must document all major component replacements, including body, etc.
