5 members (Charles in CA, klhansen, FishinToms53, Hanks custodian, 5 Window 9434), 53 guests, and 0 robots.
Topics128,049
Posts1,055,634
#823012 02/05/2012 1:21 AM
What is the approximate weight of a complete Stovebolt motor with everything on it includeing the flywheel clutch and bellhousing?
I will be going to pick up my 261 this coming week, the weight will determine if I take my lighter or heavier duty trailer. The smaller trailer has 12" wheels and is probably good for 900 lbs. and the bigger one has 15" 10 ply tires and can handle a full ton. It'll be a 12 to 1,400 mile round trip.
Guess I'm looking for opinions on what trailer to take too.
-Mike-
1945 Chevrolet G 506 1.5 Ton Military 4X4
1967 Jeep Cj5 with 283 SBC
go to search and ask for weight of a 261, I know that a 235 with a flywheel weight over 600 lbs. Hopes this helps
certainly don't weigh a ton!! engine weights here - don't think I'd take a loaded toy-wheeled trailer 1200 miles at highway speed wink
My father in law has been dragging around two four wheelers on those little tires for 20 years. Those are also the same tires on most pop-up campers. All that being said, I see no reason the smaller trailer can't do the job and do it well.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
HEAVY!
Thanks to everybody I'll be able to make up my mind with all this info!
Put in the back of a pickup and strap it down and go.
Tim
1951 3100 Chevrolet
There's a cap on my truck so there is no good way to get the motor in and out of the bed that's why I'm taking a trailer.
-Mike-
Man, I would find a way to put it in the back of the pickup and get it out, lay on side if necessary. In the bed would be way easier than towing a trailer.
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
I'll say..... Take the trailer! Trailers are fun, and easy to load; you'll feel just like a big-rig, except little-er.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
If taking the cap off is not an option,you will have to take the trailer.
Tim
1951 3100 Chevrolet
Since it is a six could lay it on is side on a pallet and slide it in with a cherry picker. Drain all the fluids out so none will spill out.
I don't have a cherry picker at home to get it out of the truck. I swap motors so seldom that I just rent one when I need it and try to keep the rental down to one day.
The motor will stay in the trailer for awhile and then get lifted out with a truck crane on another old truck I have and then get put on my engine stand and put in my work shop so I can clean it , replace the seal and gaskets and then paint it.
