2 members (J Lucas, Erniegp), 78 guests, and 2 robots.
Topics128,054
Posts1,055,780
I drug home a 48 big bolt and it has this bracket deal with an adjustable lever on the top of the driver door jamb.
http://rides.webshots.com/photo/2413795670106367558iIOVvD
I guessing there was something else attached to the bracket but not sure what. The lever adjusts back and forth. What is it?
Jason
1946 GMC COE
1967 Pontiac Lemans Convertible
http://s1275.photobucket.com/user/jrpontiac/library/?sort=3&page=1
Im guessing its the lever part for one of those "semaphore" turn signal arms?
Was there any brackets on the outside of the truck where the cable would have connected to?
Just a guess................
No there isn't anything on the outside or holes on the outside where a bracket would have been. The truck has blinkers.
Jason
1946 GMC COE
I think deluxe54panel is correct.
Here is one,it's a little different than yours. semaphore turn signal
Tim
1951 3100 Chevrolet
Brad’s got some really good pictures of the one he restored and has on his truck: http://good-times.webshots.com/photo/2029253360102454676UXpWYZ
I see how they signaled a left turn but how did you signal a right hand turn???
DG
Denny G
Sandwich, IL
Wouldn't the signal point UP for a right hand turn? I think there originally was a mounting bracket that extended the signal out a bit further from the cab making the signal easier for the driver behind you to see. Signal pointed left for a LH turn then UP for a RH turn. Just my guess.
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
yes, they worked the same as arm signals, up = right ... semaphore signals were standard on VW's up to 55, as on many European cars, but they had an arm on each side that popped out of the body
I don't think that JR's odd item is the remanents of a truck semaphore, unless it operated out an open window - need a much better picture to see detail
