| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | What is the approximate weight of a complete Stovebolt motor with everything on it includeing the flywheel clutch and bellhousing?
I will be going to pick up my 261 this coming week, the weight will determine if I take my lighter or heavier duty trailer. The smaller trailer has 12" wheels and is probably good for 900 lbs. and the bigger one has 15" 10 ply tires and can handle a full ton. It'll be a 12 to 1,400 mile round trip.
Guess I'm looking for opinions on what trailer to take too.
-Mike-
1945 Chevrolet G 506 1.5 Ton Military 4X4 1967 Jeep Cj5 with 283 SBC
| | | | | Joined: Jul 2005 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 54 | go to search and ask for weight of a 261, I know that a 235 with a flywheel weight over 600 lbs. Hopes this helps | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | certainly don't weigh a ton!! engine weights here - don't think I'd take a loaded toy-wheeled trailer 1200 miles at highway speed  Bill | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | My father in law has been dragging around two four wheelers on those little tires for 20 years. Those are also the same tires on most pop-up campers. All that being said, I see no reason the smaller trailer can't do the job and do it well. | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | | | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | Thanks to everybody I'll be able to make up my mind with all this info!
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Put in the back of a pickup and strap it down and go.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | There's a cap on my truck so there is no good way to get the motor in and out of the bed that's why I'm taking a trailer.
-Mike-
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Man, I would find a way to put it in the back of the pickup and get it out, lay on side if necessary. In the bed would be way easier than towing a trailer. 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I'll say..... Take the trailer! Trailers are fun, and easy to load; you'll feel just like a big-rig, except little-er. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | If taking the cap off is not an option,you will have to take the trailer.
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Since it is a six could lay it on is side on a pallet and slide it in with a cherry picker. Drain all the fluids out so none will spill out. | | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | Since it is a six could lay it on is side on a pallet and slide it in with a cherry picker. Drain all the fluids out so none will spill out. I don't have a cherry picker at home to get it out of the truck. I swap motors so seldom that I just rent one when I need it and try to keep the rental down to one day. The motor will stay in the trailer for awhile and then get lifted out with a truck crane on another old truck I have and then get put on my engine stand and put in my work shop so I can clean it , replace the seal and gaskets and then paint it.
