1 members (Hotrod Lincoln),
61
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 3 New Guy | | New Guy Joined: Oct 2011 Posts: 3 | after looking at several options, i decided to buy a mustang II ifs from fatman fabs; i have a 270 6 cylinder, front mounted. can the M II fit in that space? | | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | What year truck/frame? The Fatman's replacement crossmember is usually where the motor mounts will go, if you have a motor that doesn't use side-mount motor mounts, you will have to switch.
Not sure if this answers your question or not...
R-Bo
1959 Apache 1/2 ton Big Window, Short bed Fleetside (under reconstruction) 1966 GMC 305V6 in the family
| | | | | Joined: Feb 2009 Posts: 269 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 269 | Bill, I looked up your engine and the engine doesn't seem to have any side mounting wholes. It can only be mounted from the front and rear of the engine. I would have to agree, you may go with an other engine or make sure you get a IFS that doesn't require to cut the front mounting cross member if you decide to keep your current engine. Do you have any pics of your 51 GMC? Bread Update
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | most pinto based front ends wont work with the Inline 6's. make sure that yours will. I know that my IFS kit will work with the original I6. https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=790465&page=1
| | | | | Joined: Mar 2011 Posts: 229 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 229 | call the fatman he will let you know if it will work or not. also do your research before pulling the trigger on any front suspension. some need more fab than others and the prices arent that diffrent. i suggest reading the install procedures before buying. that way you know what your getting into before dropping the big bucks.
MO's 1951 chevy 3100 resto mod project
