5 members (TUTS 59, MickeyP, Oswald, Gdads51, 1 invisible), 88 guests, and 0 robots.
Topics128,049
Posts1,055,695
#822520 02/03/2012 2:33 PM
after looking at several options, i decided to buy a mustang II ifs from fatman fabs; i have a 270 6 cylinder, front mounted. can the M II fit in that space?
billkuster #822620 02/03/2012 9:57 PM
What year truck/frame? The Fatman's replacement crossmember is usually where the motor mounts will go, if you have a motor that doesn't use side-mount motor mounts, you will have to switch.
Not sure if this answers your question or not...
R-Bo
1966 GMC 305V6 in the family
R-Bo #822699 02/04/2012 1:39 AM
Bill,
I looked up your engine and the engine doesn't seem to have any side mounting wholes. It can only be mounted from the front and rear of the engine. I would have to agree, you may go with an other engine or make sure you get a IFS that doesn't require to cut the front mounting cross member if you decide to keep your current engine. Do you have any pics of your 51 GMC?
Bread
Update
1939 Chevrolet 1/2-Ton
"There and back -- repeat"
Bread #822733 02/04/2012 3:29 AM
most pinto based front ends wont work with the Inline 6's.
make sure that yours will.
I know that my IFS kit will work with the original I6.
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=790465&page=1
Scott Danforth #822828 02/04/2012 2:26 PM
mo Offline
call the fatman he will let you know if it will work or not. also do your research before pulling the trigger on any front suspension. some need more fab than others and the prices arent that diffrent. i suggest reading the install procedures before buying. that way you know what your getting into before dropping the big bucks.
MO's 1951 chevy 3100 resto mod project
