2 members (NJC, baldeagle),
33
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#82257 08/29/2007 9:25 PM | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Now that I have the driver’s side front fender and inner fender off of my ’41 it could be a good time to try and free up the hear riser on the stock 216. Does anyone have any good tricks, short of removing the manifold and drilling it out right after I manage to break the shaft??? | | |
#82258 08/29/2007 9:53 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Kip's41,
Heat, Kroil, wiggle, Kroil, wiggle, heat, tap, wiggle, Kroil, wait, cross fingers and chant! If the bi metal spring is still intact, remove it before the heat phase of the recipe.
That spring sometimes breaks off in the slit in the shaft. If this is the case, removal of the manifold would make this repair much easier.
Stuart | | |
#82259 08/29/2007 10:45 PM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | If you can't get it working, I think that the Car and Truck Shop in CA sells new units. | | |
#82260 08/30/2007 12:39 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | A lot of times the flapper is burnt out, so even if you unstick the shaft it may not do any good.
#82261 08/30/2007 6:57 PM | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Thanks guys, about what I figured | | |
#82262 08/30/2007 7:21 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Kip's41, If you are determined to repair the heat riser properly, it will probably require you to remove the intake/exhaust combo to separate the two and gain access to the heat riser innards. The bolts that secure the two manifolds to each other will sometimes break when wrenched on. This means new bolts, easy outs and much creativity. Although it doesn't always happen this way, that area is usually a 'frozen zone'. If all this were to happen, with just a bit more energy, you could have the manifold combo surfaced at a auto machine shop and the whole enchilada would be good for another 40 years. If you can fix the heat riser to your satisfaction from the outside, this all becomes a moot point. These are just some points to think about. Stuart | | |
#82263 09/01/2007 2:29 PM | Joined: Apr 2007 Posts: 29 Apprentice | | Apprentice Joined: Apr 2007 Posts: 29 | I have a 61 fleetside that had the same problem. I sprayed penetrating oil all over it several times then semi-gently tapped the ends of the rod both ways, soaked it some more. Finally it broke loose. Now it is free and can easily turn bt the spring tension. Good luck. | | |
#82264 09/01/2007 2:40 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Mine was stuck open and is still stuck open. I decided it wasn't worth the hassle in trying to unstick it.
#82265 09/02/2007 2:12 PM | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Hay Tiny, this may sound like a dumb question but when looking from the out side which way is the large counter weight when the thing is open ?? I did know at one time, but that was about 1959 and I have forgotten | | |
#82266 09/02/2007 2:34 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | The weight on mine appears to be pretty much at the 12 o'clock position.
#82267 09/03/2007 2:09 PM | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | | | |
#82268 09/03/2007 2:44 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | When the weight is horizontal it is closed. When it's open it's at about a 45 degree angle. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
